Fusion OS AidLux
Programming Environment
Python
AidLux has a built-in Python version.
aidlux@aidlux:~$ python3
Python 3.8.10 (default, Nov 22 2023, 10:22:35)
[GCC 9.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
C & C++
[Install gcc, g++, clang, gdb]
sudo apt install -y gcc g++ clang gdb
[Verification]
gcc -v
g++ -v
clang -v
gdb -v
Go
  • Update package index: First, update your package index to ensure you install the latest versions of the packages.
  • Install Go: You can install Go directly using the apt package manager.
sudo apt install golang-go
This will install the Go language environment along with its standard library.
  • Verification: After installation, you can verify that Go has been installed correctly by running the following command:
go version
  • Test: Create go.test:
go
package main
import "fmt"
func main() { fmt.Printf("hello, world\n") }
Result:
aidlux@aidlux:~$ go run test.go
hello, world
Java
  • Install OpenJDK JDK
sudo apt install default-jre
  • Verification
aidlux@aidlux:~$ java --version
openjdk 11.0.24 2024-07-16
OpenJDK Runtime Environment (build 11.0.24+8-post-Ubuntu-1ubuntu320.04)
OpenJDK 64-Bit Server VM (build 11.0.24+8-post-Ubuntu-1ubuntu320.04, mixed mode)
PHP
  • Install
sudo apt install php
  • Check Version
aidlux@aidlux:~$  php -version
PHP 7.4.3-4ubuntu2.24 (cli) (built: Sep 30 2024 18:16:20) ( NTS )
Copyright (c) The PHP Group
Zend Engine v3.4.0, Copyright (c) Zend Technologies
    with Zend OPcache v7.4.3-4ubuntu2.24, Copyright (c), by Zend Technologies
Vue.js
Using nvm (Node Version Manager)
nvm is a Node.js version manager that allows you to install and switch between different versions of Node.js.
  • First, install nvm:
wget -qO- https://raw.githubusercontent.com/nvm-sh/nvm/v0.39.1/install.sh | bash
  • Then, close and reopen your terminal, or run the following command to enable nvm:
export NVM_DIR="$([ -z "${XDG_CONFIG_HOME-}" ] && printf %s "${HOME}/.nvm" || printf %s "${XDG_CONFIG_HOME}/nvm")"
[ -s "$NVM_DIR/nvm.sh" ] && \. "$NVM_DIR/nvm.sh" # This loads nvm
  • Install Node.js:
nvm install node  # Install the latest version
nvm install 16    # Install a specific version, e.g., 16.x
  • Check Node.js Version:
aidlux@aidlux:~$ node -v
v23.0.0
aidlux@aidlux:~$ npm -v
10.9.0
Rust
Install
apt install -y rustc rust-src rust-gdb rust-doc rustdoc-stripper
Verification
aidlux@aidlux:~$ rustc --version
rustc 1.75.0 (82e1608df 2023-12-21) (built from a source tarball)
Last updated:
