AidLLM C++ API Documentation ​
When developing with AidGen-SDK C++, you need to know the following basic information:
  • Include the header file during compilation, located at /usr/local/include/aidlux/aidgen/aidllm.hpp
  • Specify the library file during linking, located at /usr/local/lib/libaidgen.so
Inference Backend Type.enum LLmBackendType ​
For AidllmSDK, it supports using different inference backend frameworks to implement large model inference tasks. The inference backends involved are shown below.
Member Variable NameTypeValueDescription
TYPE_DEFAULTuint8_t0Unknown backend type
TYPE_GENIEuint8_t1Genie inference backend
Inference Task Status.enum LLMSentenceState ​
During the completion of inference tasks, Aidllm may have various states for a single conversation. Developers can understand the current inference task's running status through these status codes.
BEGINuint8_t0Beginning of conversation
CONTINUEuint8_t1Continuous inference content in conversation
ENDuint8_t2End of conversation
COMPLETEuint8_t3Current conversation successfully completed
ABORTuint8_t4Current conversation passively terminated
ERRORuint8_t5Current conversation inference error
Log Level.enum LogLevel ​
AidllmSDK provides interfaces for setting logs (to be introduced later), which require specifying the log level to use, so this log level enumeration is needed.
INFOuint8_t0Information
WARNINGuint8_t1Warning
ERRORuint8_t2Error
FATALuint8_t3Fatal error
Inference Callback Function Data Type.struct LLMCallbackData ​
Aidllm uses callback functions provided by developers during inference tasks. This data type is the parameter passed to the callback function, which developers can use to handle inference result data in their custom callback functions.
Member Variable List ​
The Config object is used to set runtime configuration information, including the following parameters:
Member Variable state
Type enum LLMSentenceState
Default Value
Description Status code of the current inference conversation
Member Variable text
Type std::string
Default Value
Description Result characters/prompt messages corresponding to special status codes of the inference task
Runtime Context Class.class LLMContext ​
During Aidllm runtime, some configuration information may need to be set, and runtime-related data also needs to be passed. This runtime context class object is used to complete data flow.
Create Instance Object.create_instance() ​
To set runtime context information, you need to have a configuration instance object first. This function is used to create an instance object of LLMContext type.
API create_instance
Description Used to construct an instance object of LLMContext class
Parameters config_file: Initial configuration file, which can configure key information such as backend type, model file name, etc.
Return Value If nullptr, the function failed to build the object; otherwise, it's a pointer to the LLMContext object
// Create configuration instance object, return null value indicates error
Member Variable config_file
Type std::string
Default Value
Description Initial configuration file, configuration file parameter passed when creating object
Member Variable backend_type
Type LLmBackendType
Default Value LLmBackendType.TYPE_DEFAULT
Description The configuration file requires developers to specify the inference backend. After the initialization operation parses the configuration file, this field will be overwritten to identify the backend type specified by the developer
Member Variable model_file_vec
Type std::vector<std::string>
Default Value
Description The configuration file requires developers to specify model files. After the initialization operation parses the configuration file, this field will be overwritten to identify the model files specified by the developer
Member Variable config_overwrite_options
Type std::string
Default Value
Description By setting this field, certain key parameters in the inference process can be specified, thereby affecting inference speed, inference results, etc.
Member Variable android_tmp_directory
Type std::string
Default Value
Description This field is only valid on Android platform. By setting this field, directories with legal permissions for system users can be specified for inference programs to borrow
Interpreter Class.class LLMInterpreter ​
LLMInterpreter class object instances are the main body for executing inference operations, used to perform specific inference processes.
To execute inference-related operations, an inference interpreter is essential. This function is used to build an instance object of the inference interpreter.
API create_instance
Description Construct an LLMInterpreter type object using various data managed by the LLMContext object
Parameters llm_context: Pointer to LLMContext instance object
Return Value If nullptr, the function failed to build the object; otherwise, it's a pointer to the LLMInterpreter object
 // Create interpreter object using LLMContext object pointer, return null value indicates error
Initialize Operation.initialize() ​
After the interpreter object is created, some initialization operations need to be performed, such as environment checking, resource building, etc.
API initialize
Description Complete the relevant initialization work required for inference
Parameters void
Return Value 0 value indicates successful initialization operation, otherwise non-0 value indicates execution failure
// Initialize interpreter, return non-zero value indicates error
Conversation Inference Operation.run() ​
After successfully completing the initialization operation, you can execute dialogue operations with the large model. Developers provide custom callback functions to handle continuous inference results during the conversation process.
API run
Description Execute one conversation inference
Parameters prompt: Prompt string
cb: Custom callback function provided by developers to handle continuous inference results during the conversation process
user_data: Pointer to user data, convenient for using this data in custom callback functions
Return Value 0 value indicates successful execution of release operation, otherwise non-0 value indicates execution failure
Conversation Termination Operation.abort() ​
Users may want to interrupt the currently executing inference conversation in certain situations. This function is used to implement inference termination.
API abort
Description Terminate the currently running inference conversation
Parameters void
Finalize Release Operation.finalize() ​
As mentioned earlier, the interpreter object needs to execute initialize() initialization-related operations. Correspondingly, the interpreter also needs to execute some release operations to destroy previously created resources, etc.
API finalize
Description Complete necessary de-initialization release operations
Parameters void
// Execute interpreter de-initialization process, return non-zero value indicates error
Last updated:
