AidLite Python API Documentation ​
Model Data Types class DataType ​
For AidliteSDK, it handles different models from different frameworks, and each model has its own different input data types and different output data types. In the aforementioned usage workflow, you need to set the input and output data types of the model, which requires using this data type.
Member Variable NameTypeValueDescription
TYPE_DEFAULTint0Invalid DataType type
TYPE_UINT8int1Unsigned byte data
TYPE_INT8int2Byte data
TYPE_UINT32int3Unsigned int32 data
TYPE_FLOAT32int4Float data
TYPE_INT32int5Int32 data
TYPE_INT64int6Int64 data
TYPE_UINT64int7Uint64 data
TYPE_INT16int8Int16 data
TYPE_UINT16int9Uint16 data
TYPE_FLOAT16int10Float16 data
TYPE_BOOLint11Bool data
Inference Implementation Type class ImplementType ​
TYPE_DEFAULTint0Invalid ImplementType type
TYPE_MMKVint1Implementation through MMKV (currently no related implementation, may be removed later)
TYPE_REMOTEint2Backend implementation through IPC
TYPE_LOCALint3Backend implementation through local calls
Model Framework Type class FrameworkType ​
As mentioned earlier, Aidlite SDK integrates multiple deep learning inference frameworks, so in the aforementioned usage workflow, you need to set which framework's model is currently being used, which requires using this framework type.
TYPE_DEFAULTint0Invalid FrameworkType type
TYPE_SNPEint1SNPE 1.x (DLC) model
TYPE_TFLiteint2TFLite model
TYPE_RKNNint3RKNN model
TYPE_QNNint4QNN model
TYPE_SNPE2int5SNPE 2.x (DLC) model
TYPE_NCNNint6NCNN model
TYPE_MNNint7MNN model
TYPE_TNNint8TNN model
TYPE_PADDLEint9Paddle model
TYPE_MSint10MindSpore model
TYPE_ONNXuint8_t11ONNX model
TYPE_QNN216uint8_t101QNN2.16 model
TYPE_SNPE216uint8_t102SNPE2.16 model
TYPE_QNN223uint8_t103QNN2.23 model
TYPE_SNPE223uint8_t104SNPE2.23 model
TYPE_QNN229uint8_t105QNN2.29 model
TYPE_SNPE229uint8_t106SNPE2.29 model
TYPE_QNN231uint8_t107QNN2.31 model
TYPE_SNPE231uint8_t1068SNPE2.31 model
Special notes:
  • If the user environment has multiple backend implementation software packages such as AidLite-QNN216/AidLite-QNN223/AidLite-QNN229 installed simultaneously, and the FrameworkType in the code is set to TYPE_QNN (i.e., without specifying which specific version of QNN backend to use), then the actual running QNN backend should be the one with the highest QNN version (i.e., AidLite-QNN229 will be prioritized to complete inference).
  • Different QNN version backend software packages cannot be used simultaneously in the same program, which means if the program first specifies TYPE_QNN216 to complete inference, then TYPE_QNN223/TYPE_QNN229 cannot be used for inference.
Inference Acceleration Hardware Type class AccelerateType ​
For each deep learning inference framework, it may support running on different acceleration hardware units (such as SNPE/QNN models running on Qualcomm DSP computing units, RKNN models running on Rockchip NPU computing units), so in the aforementioned usage workflow, you need to set which computing unit the current model is expected to run on, which requires using this acceleration hardware unit type.
TYPE_DEFAULTint0Invalid AccelerateType type
TYPE_CPUint1CPU general acceleration unit
TYPE_GPUint2GPU general acceleration unit
TYPE_DSPint3Qualcomm DSP acceleration unit
TYPE_NPUint4NPU general acceleration unit
Log Level class LogLevel ​
AidliteSDK provides an interface for setting logs (which will be introduced later), which requires providing the interface with which log level to use currently, so this log level needs to be used.
INFOint0Information
WARNINGint1Warning
ERRORint2Error
FATALint3Fatal error
Input/Output Information class TensorInfo ​
Each model has its own inputs and outputs. For models that developers are not familiar with, during development they may need to query the input and output Tensor information of the model to facilitate developers in performing pre and post-processing operations for model inference. Aidlite provides developers with an interface to query detailed information about model inputs and outputs.
Member Variable List ​
The TensorInfo object is used to store detailed information about the model's input and output Tensors, including the following parameters:
Member Variable version
Type uint32_t
Default Value No default value
Description This member is used to identify the TensorInfo version. If more information needs to be extended in the future, the version number will be updated
Member Variable index
Type uint32_t
Description Index value of the Tensor
Member Variable name
Type std::string
Description Name string of the Tensor
Member Variable element_count
Type uint64_t
Default Value 0
Description Number of data elements in the Tensor
Member Variable element_type
Type enum DataType
Default Value DataType::TYPE_DEFAULT
Description Type of data elements in the Tensor
Member Variable dimensions
Type uint32_t
Default Value 0
Description Dimension value of data elements in the Tensor
Member Variable shape
Type std::vector< uint64_t >
Description Shape description of data elements in the Tensor
Model class Model ​
As mentioned earlier, before creating an inference interpreter, you need to set specific detailed parameters related to the model. The Model class is mainly used to record the model's file information, structural information, and model-related content during runtime.
Create Model Instance Object create_instance() ​
To set detailed information related to the model, you naturally need to have a model instance object first. This function is used to create a Model instance object.
API create_instance
Description Constructs a Model type instance object by passing the path name of the model file
Parameters model_path: Path name of the model file
Return Value Normal: Model instance object
Exception: None
# Create model object using inceptionv3_float32.dlc file in current path, error if return value is empty
model = aidlite.Model.create_instance(model_path=r"./inceptionv3.dlc")
if model is None:
    return False
Set Model Properties set_model_properties() ​
After the model instance object is created successfully, you need to set the input and output data types of the model and the shape information of the input and output tensor data.
API set_model_properties
Description Set model properties, input and output data shape and data types.
Parameters input_shapes: Shape array of input tensors, two-dimensional array structure.
input_data_type: Data type of input tensors, DataType enumeration type.
output_shapes: Shape array of output tensors, two-dimensional array structure.
output_data_type: Data type of output tensors, DataType enumeration type.
Return Value Model file path string object corresponding to the Model object
# Data type uses the aforementioned DataType, input and output shapes are two-dimensional arrays
input_shapes=[[1,640,640,3]]
output_shapes=[[1,10,10,255], [1,20,20,255], [1,40,40,255]]
model.set_model_properties(input_shapes=input_shapes, input_data_type=aidlite.DataType.TYPE_FLOAT32, output_shapes=output_shapes, output_data_type=aidlite.DataType.TYPE_FLOAT32)
Get Model Path get_model_absolute_path() ​
API get_model_absolute_path
Description Used to get the existing path of the model file
Parameters None
model_path = model.get_model_absolute_path()
Get Model Framework Type get_model_type() ​
API get_model_type
Description Used to get the model type identifier, such as different model categories like DLC, RKNN, etc.
Parameters None
model_type = model.get_model_type()
Configuration class Config ​
As mentioned earlier, before creating an inference interpreter, in addition to setting specific Model information, you also need to set some configuration information for inference. The Config class is used to record configuration options that need to be set in advance, and these configuration items will be used at runtime.
Create Config Instance Object create_instance() ​
To set runtime configuration information, you naturally need to have a configuration instance object first. This function is used to create a Config instance object.
API create_instance
Description Used to construct an instance object of the Config class
Parameters snpe_out_names: List of model output node names (optional)
number_of_threads: Number of threads, valid when greater than 0 (optional)
is_quantify_model: Whether it's a quantized model, 1 indicates quantized model for FAST (optional)
fast_timeout: Interface timeout (milliseconds, valid when greater than 0) for FAST (optional)
accelerate_type: Type of acceleration hardware (optional)
framework_type: Type of underlying deep learning framework (optional)
Return Value Normal: Config instance object
Exception: None
# Create configuration instance object, error if return value is None
if config is None:
    print("Create config failed !")
    return False
The Config object is used to set runtime configuration information, including the following parameters:
Member Variable accelerate_type
Default Value AccelerateType.TYPE_CPU
Description Type of acceleration hardware
Member Variable implement_type
Default Value ImplementType.TYPE_LOCAL
Description Distinction of underlying function implementation approach
Member Variable framework_type
Default Value FrameworkType.TYPE_DEFAULT
Description Type of underlying inference framework
Member Variable number_of_threads
Type int
Default Value -1
Description Number of threads, valid when greater than 0
Member Variable SNPE_out_names
Type list
Default Value None
Description List of model output node names
Member Variable is_quantify_model
Type int
Default Value 0
Description Whether it's a quantized model, 1 indicates quantized model (only Remote needs to be set)
Member Variable remote_timeout
Type int
Default Value -1
Description Interface timeout (milliseconds, valid when greater than 0) (only Remote needs to be set)
config.framework_type = aidlite.FrameworkType.TYPE_SNPE
config.is_quantify_model = 1
config.SNPE_out_names = ["InceptionV3/Softmax"]
config.fast_timeout = 1000
Context Class class Context ​
Used to store runtime context involved in the execution process, including Model objects and Config objects, and may be extended to include runtime data in the future.
Constructor Context() ​
API Context
Description Construct a Context instance object
Parameters model: Model instance object
config: Config instance object
Return Value Normal: Context instance object
Exception: None
context = aidlite.Context(model=model, config=config)
Get Model Member Variable get_model() ​
API get_model
Description Get the Model object managed by context
Parameters None
Return Value Model object
model = context.get_model()
Get Config Member Variable get_config() ​
API get_config
Description Get the Config object managed by context
Parameters None
Return Value Config object
config = context.get_config()
Interpreter Class class Interpreter ​
The Interpreter class object instance is the main entity that executes inference operations and is used to perform specific inference processes. In the inference workflow mentioned earlier, after creating the interpreter object, all operations are completed based on the interpreter object, making it the absolute core content of AidliteSDK.
Create Interpreter Instance Object create_instance() ​
To execute inference-related operations, the inference interpreter is essential. This function is used to build an instance object of the inference interpreter.
API create_instance
Description Use the various data managed by the Context object to construct an Interpreter type object.
Parameters None
Return Value Normal: Interpreter instance object
Exception: None
# Create interpreter object, return value of None indicates error
interpreter = aidlite.Interpreter.create_instance()
if interpreter is None:
    print("Create Interpreter failed !")
    return False
Initialize init() ​
After the interpreter object is created, some initialization operations need to be performed (such as environment checking, resource construction, etc.).
API create_instance
Parameters context: Context object instance. It manages Model and Config objects, which contain model data, configuration data, etc.
Return Value Normal: 0
Exception: Non-zero
# Initialize interpreter, non-zero return value indicates error
result = aidlite.interpreter.init()
if result != 0:
    printf("sample : interpreter->init() failed !")
    return False
Load Model load_model() ​
After the interpreter object completes the initialization operation, the required model file can be loaded for the interpreter to complete the model loading work. The subsequent inference process uses the loaded model resources.
API load_model
Description Complete model loading related work. Since the model file path has been set in the Model object previously, the model loading operation can be executed directly
Parameters None
Exception: Non-zero
# Load model with interpreter, non-zero return value indicates error
result = interpreter.load_model()
if result != 0:
    print("sample : interpreter->load_model() failed !")
    return False
Get Input Tensor Details get_input_tensor_info() ​
If you want to get detailed information about the model's input Tensor, you can use this interface to obtain it.
API get_input_tensor_info
Description Get detailed information about input Tensors in the model
Return Value Normal: Two-dimensional array of TensorInfo type data
Exception: None
Special Note This interface is supported from version 2.2.5 onwards
# Get detailed information about model input Tensors
input_tensor_info = onnx_interpreter.get_input_tensor_info()
if len(input_tensor_info) == 0 :
    printf("interpreter get_input_tensor_info() failed !\n")
    return False
for gi, graph_tensor_info in enumerate(input_tensor_info):
    for ti, tensor_info in enumerate(graph_tensor_info):
        print(  f"Input  tensor : Graph[{gi}]-Tensor[{ti}]-name[{tensor_info.name}]"
                f"-element_count[{tensor_info.element_count}]-element_type[{tensor_info.element_type}]"
                f"-dimensions[{tensor_info.dimensions}]-shape{tensor_info.shape}")
Get Output Tensor Details get_output_tensor_info() ​
If you want to get detailed information about the model's output Tensor, you can use this interface to obtain it.
API get_output_tensor_info
Description Get detailed information about output Tensors in the model
Exception: None
# Get detailed information about model output Tensors
output_tensor_info = onnx_interpreter.get_output_tensor_info()
if len(output_tensor_info) == 0 :
    printf("interpreter get_output_tensor_info() failed !\n")
    return False
for gi, graph_tensor_info in enumerate(output_tensor_info):
        print(  f"Output tensor : Graph[{gi}]-Tensor[{ti}]-name[{tensor_info.name}]"
Set Input Data set_input_tensor() ​
As mentioned when introducing the workflow, before setting input data, different preprocessing operations need to be completed for different models to adapt to specific models.
API set_input_tensor
Description Execute inference computation process
Parameters in_tensor_tag: Index value or name string of input tensor, type is int or str
input_data: Binary data of input tensor, type is passed according to actual situation
Exception: Non-zero
Special Note Parameter in_tensor_tag supports name string from version 2.2.5 onwards
# Set input data for inference, non-zero return value indicates error
result = interpreter.set_input_tensor(in_tensor_tag=1, input_data=obj)
#result = interpreter.set_input_tensor(in_tensor_tag="input_tensor_name", input_data=obj)
if result != 0:
    print("interpreter->set_input_tensor() failed !")
    return False
Execute Inference invoke() ​
As mentioned when introducing the workflow, after setting the input data, the next step is naturally to execute the inference running process on the input data.
API invoke
Parameters None
Exception: Non-zero
# Execute inference operation, non-zero return value indicates error
result = interpreter.invoke()
if result != 0:
    print("sample : interpreter->invoke() failed !")
    return False
Get Output Data get_output_tensor() ​
After inference is completed, the result data obtained from inference needs to be extracted. As mentioned when introducing the workflow, after extracting the result data, this result data can be processed to determine whether the result is correct.
Description After successful inference, get inference result data
Parameters out_tensor_tag: Index value or name string of result output tensor, type is int or str
output_type: Type of result output, optional parameter, defaults to aidlite.DataType.TYPE_FLOAT32 if not passed
Return Value Normal: float result data.
Exception: None.
Special Note Parameter out_tensor_tag supports name string from version 2.2.5 onwards
# Get inference result data, return value of None indicates error
out_data = interpreter.get_output_tensor(out_tensor_tag=1, output_type=aidlite.DataType.TYPE_INT32)
#out_data = interpreter.get_output_tensor(out_tensor_tag="output_tensor_name", output_type=aidlite.DataType.TYPE_INT32)
if out_data is None:
    print("interpreter->get_output_tensor() failed !")
    return False
Resource Release destroy() ​
As mentioned earlier, the interpreter object needs to perform init initialization operations and load model operations. Correspondingly, the interpreter also needs to perform some release operations to destroy the previously created resources.
API destroy
Description Complete necessary release operations
Parameters None
Exception: Non-zero
# Execute interpreter release process, non-zero return value indicates error
result = interpreter.destroy()
if result != 0:
    print("sample : interpreter-> destroy() failed !")
    return False
Interpreter Builder Class class InterpreterBuilder ​
Unified creation function for Interpreter objects, create required interpreter objects through this class.
Build Interpreter build_interpreter_from_path() ​
Build inference interpreter object, can provide different parameters, the simplest is to provide only the path and name of the model file.
API build_interpreter_from_path
Description Directly create corresponding interpreter object through the path name of the model file. All related parameters use default values
Parameters path: Path name of the model file
Return Value Normal: Interpreter object instance
Exception: None
# Build interpreter by passing Model file path, return value of None indicates error
interpreter = aidlite.InterpreterBuilder.build_interpreter_from_path(path=r"./640.dlc")
    return False
Build Interpreter build_interpreter_from_model() ​
Build inference interpreter object, in addition to providing the model file path, you can also provide a Model object, so that you can not only set the path name of the model file, but also set the input and output data types of the model and the shape information of input and output data.
API build_interpreter_from_model
Description Create corresponding interpreter object by passing Model object. Config related parameters all use default values
Parameters model: Model type object containing model-related data
Exception: None
# Build interpreter by passing Model object, return value of None indicates error
interpreter = aidlite.InterpreterBuilder.build_interpreter_from_model(model=model)
    return False
Build Interpreter build_interpreter_from_model_and_config() ​
Build inference interpreter object, in addition to the two methods mentioned above, you can also provide both Model object and Config object, so that you can not only provide model-related information, but also provide more runtime configuration parameters.
API build_interpreter_from_model_and_config
Description Create corresponding interpreter object by passing Model object and Config.
config: Config type object containing some configuration parameters
Exception: None
# Build interpreter by passing Model and Config objects, return value of None indicates error
interpreter = aidlite.InterpreterBuilder.build_interpreter_from_model_and_config(model=model, config=config)
    return False
Other Methods ​
Get SDK Version Information get_library_version() ​
API get_library_version
Description Used to get version-related information of the current Aidlite-SDK
Parameters None
Return Value Returns version information string of the current Aidlite-SDK
Get Python SDK Version Information get_library_version() ​
API get_py_library_version
Description Used to get version-related information of the current Py-Aidlite-SDK
Parameters None
Return Value Returns version information string of the current Py-Aidlite-SDK
Set Log Level set_log_level() ​
API set_log_level
Description Set the current minimum log level, output log data greater than or equal to this log level. By default, prints WARNING and above level logs.
Parameters log_level: LogLevel type value
Return Value Returns 0 by default
Log Output to Standard Terminal log_to_stderr() ​
API log_to_stderr
Description Set log information output to standard error terminal
Parameters None
Log Output to Text File log_to_file() ​
API log_to_file
Description Set log information output to specified text file
Parameters path_and_prefix: Storage path and name prefix for log file
also_to_stderr: Flag indicating whether to simultaneously output logs to stderr terminal, default value is False
Exception: Non-zero
Get Latest Log Information last_log_msg() ​
API last_log_msg
Description Get the latest log information for a specific log level, typically used to retrieve the latest error information
Parameters log_level: Value of LogLevel type
Return Value Latest log information
Last updated:
