| 1 | realpath [***] failed. errmsg: No such file or directory | The model file path is incorrect or the model file does not exist. | Ensure the model file exists and the path is correct. |
| 2 | model file [***] maybe path abnormal | The model file path is incorrect or the model file does not exist. | Ensure the model file exists and the path is correct. |
| 3 | Read sysbase info file failed | Failed to read the system base information file. | Ensure the /etc/opt/aidlux/aidsys file exists and is readable. |
| 4 | Parse sysbase info failed | The content of the system base information file is abnormal. | Check the content of /etc/opt/aidlux/aidsys for abnormalities. |
| 5 | Current aidlux don't support DLC model | The current Aidlux does not support DLC model inference. | DLC models are only supported on qc8250/qc6490/qc8550 platforms. Check if you're using one of these boards. |
| 6 | Current aidlux don't support RKNN model | The current Aidlux does not support RKNN model inference. | RKNN models are only supported on the rk3588 platform. Check if you're using this board. |
| 7 | Unknown framework type | The FrameworkType type is not set. | Set the correct FrameworkType enumeration value for the model file. |
| 8 | Basic Aidlux don't support DSP/NPU | The Basic version of Aidlux does not support DSP/NPU hardware acceleration. | Use the enterprise version of Aidlux to access DSP/NPU acceleration. |
| 9 | Not support ImplementType::TYPE_&& FrameworkType::TYPE_ | The current Aidlux does not support this ImplementType + FrameworkType combination. | Check and confirm that the correct Aidlite version is installed. |
| 10 | Please activate the device to use DSP/NPU | DSP/NPU hardware acceleration is only available on an activated Aidlux device. | Ensure that Aidlux is activated on your device. |
| 11 | Error while building SNPE object. ***. error_code=204; error_message=Couldn't find name. One or more specified output layers don't exist. | Failed to construct SNPE object. | Check if the snpe_out_names attribute of the Config object is filled correctly with the Node Name attribute from the model file. |
| 12 | fast init attach_ashmem failed | Failed to connect to the services needed by the ImplementType::Fast implementation. | A reboot of the Aidlux platform is usually needed to restart the dependent services. |
