Deploying LLM with AidGen ​
Deploying a Large Language Model (LLM) on edge devices refers to compressing, quantizing, and deploying large models that originally run in the cloud onto local devices, enabling offline, low-latency natural language understanding and generation. This chapter is based on the AidGen inference engine and demonstrates how to perform LLM deployment, loading, and conversation on edge devices.
In this case, the large language model inference runs on the device side, and the relevant interfaces are called through C++ code to receive user input and return conversation results in real time.
  • Device: Rhino Pi-X1
  • System: Ubuntu 22.04
  • Model: Qwen2.5-0.5B-Instruct
Supported Platforms ​
PlatformRunning Method
Preparation ​
  1. Rhino Pi-X1 hardware
  3. Prepare the model files
Visit Model Farm: Qwen2.5-0.5B-Instruct to download the model resource files.
Select the QCS8550 chip.
Case Deployment ​
Step 1: Install the AidGen SDK ​
# Install AidGen SDK
sudo aid-pkg -i aidgen-sdk
sudo aid-pkg -i aidgen-qnn236
sudo aid-pkg -i aidgen-qnn240
# Copy test code
cd /home/aidlux/aidllm
Step 2: Obtain Model Resources ​
# Log in
mms login
# Search for the model
# Download the model
mv qnn229_qcs8550_cl4096/* /home/aidlux/aidllm/
Step 3: Confirm Resource Files ​
/home/aidlux/aidllm
├── aidgen_chat_template.txt
├── chat.txt
├── qwen2.5-0.5b-instruct-htp.json
├── qwen2.5-0.5b-instruct-tokenizer.json
├── qwen2.5-0.5b-instruct_qnn229_qcs8550_4096_1_of_2.serialized.bin
├── qwen2.5-0.5b-instruct_qnn229_qcs8550_4096_2_of_2.serialized.bin
├── examples
Step 4: Set the Conversation Template ​
For the conversation template, refer to the aidgen_chat_template.txt file in the model resource package.
Modify the test_aidgen_text.cpp file according to the large model's template:
    // 5. Build the prompt template (Qwen2 format)
    std::string system_prompt =
        "<|im_start|>system\n"
        "You are Qwen, created by Alibaba Cloud. You are a helpful assistant.<|im_end|>\n";
    auto make_user_turn = [](const std::string& text) -> std::string {
        return "<|im_start|>user\n" + text + "<|im_end|>\n<|im_start|>assistant\n";
Step 5: Compile and Run ​
# Compile
mkdir build && cd build
cmake .. && make
./test_text_only qwen2.5-0.5b-instruct-htp.json "hi"
Log Information
