Streaming TTS Output (Linux) ​
This case study demonstrates how to use the AidVoice SDK to implement real-time streaming speech synthesis and audio playback on a Linux system.
Supported Platforms ​
PlatformExecution Method
Prerequisites ​
  1. Rhino Pi-X1 hardware.
  2. Ubuntu 22.04 system or AidLux system.
  3. USB speaker/microphone setup.
Case Deployment ​
Step 1: Install AidVoice SDK ​
# Install AidLite QNN version 2.36
# Install AidVoice SDK
sudo aid-pkg -i aidvoice-sdk
Step 2: Model Acquisition ​
# Obtain MeloTTS-English
mms get -m MeloTTS-English -p fp16 -c qcs8550 -b qnn2.31 -d /home/aidlux/melotts-english
cd /home/aidlux/melotts-english
unzip MeloTTS-English_qcs8550_fp16.zip
Step 3: Test Code Compilation ​
# Copy test code
# Compile
mkdir -p build && cd build
cmake ..
make
Step 4: Confirm Device ID ​
Plug in the USB speaker/microphone.
sudo ./test_file -c
You should see output similar to the following, where the ID for "Jabra SPEAK 410 USB" is 15:
found 16 capture devices:
    - Capture device #0: 'kalama-qrd-snd-card, '
    - Capture device #1: 'kalama-qrd-snd-card,  (2)'
    - Capture device #2: 'kalama-qrd-snd-card,  (3)'
    - Capture device #3: 'kalama-qrd-snd-card,  (4)'
    - Capture device #4: 'kalama-qrd-snd-card,  (5)'
    - Capture device #5: 'kalama-qrd-snd-card,  (6)'
    - Capture device #6: 'kalama-qrd-snd-card,  (7)'
    - Capture device #7: 'kalama-qrd-snd-card,  (8)'
    - Capture device #8: 'kalama-qrd-snd-card,  (9)'
    - Capture device #9: 'kalama-qrd-snd-card,  (10)'
    - Capture device #10: 'kalama-qrd-snd-card,  (11)'
    - Capture device #11: 'kalama-qrd-snd-card,  (12)'
    - Capture device #12: 'kalama-qrd-snd-card,  (13)'
    - Capture device #13: 'kalama-qrd-snd-card,  (14)'
    - Capture device #14: 'kalama-qrd-snd-card,  (15)'
    - Capture device #15: 'Jabra SPEAK 410 USB, USB Audio'
Step 5: Run the Example ​
# -m model path
# -i device ID
# -f input text file path
sudo ./test_file -m /home/aidlux/melotts-english/models/QCS8550/FP16 -i 15 -f ../text_file.txt
