SAM2 Deployment ​
Segment-Anything-Model-2 (SAM 2) is the next generation of visual segmentation foundation models released by Meta AI. It supports real-time interactive segmentation of any object in both images and videos. Compared to the previous version, SAM 2 utilizes a unified Transformer architecture and integrates a streaming memory mechanism for video segmentation, allowing it to achieve precise and continuous object tracking with minimal interaction prompts.
This chapter demonstrates the deployment, loading, and inference process of SAM 2 on edge devices. The following deployment method is provided:
  • AidLite Python API
In this case, model inference runs on the device-side NPU computing unit. The code calls the relevant interfaces to receive user input and return results.
  • Device: Rhino Pi-X1
  • System: Ubuntu 22.04
  • Source Model: SAM2 Tiny
  • Model Precision: FP16
  • Model Farm Reference: SAM2 Tiny
Supported Platforms ​
PlatformExecution Method
Prerequisites ​
  1. Rhino Pi-X1 hardware.
  2. Ubuntu 22.04 system or AidLux system.
Download SAM2-tiny-FP16 Model Resources ​
mms list sam2-tiny
#------------------------ SAM2-tiny models available ------------------------
Model      Precision  Chipset          Backend
SAM2-tiny  FP16       Qualcomm QCS8550  QNN2.36
# Download SAM2-tiny-FP16
mms get -m SAM2-tiny -p fp16 -c qcs8550 -b qnn2.36 -d /home/aidlux/sam2-tiny
cd /home/aidlux/sam2-tiny
# Unzip
unzip sam2_qcs8550_qnn2.36_fp16_aidlite.zip
Developers can also search and download models on the Model Farm website.
AidLite SDK Installation ​
  • Ensure the QNN backend version is ≥ 2.36.
  • Ensure the versions of aidlite-sdk and aidlite-qnnxxx are 2.3.x.
dpkg -l | grep aidlite
#------------------------ You should see output similar to this ------------------------
ii  aidlite-sdk           2.3.0.230         arm64        aidlux inference module sdk
Update QNN & AidLite versions:
# Install AidLite SDK
# AidLite SDK C++ check
# AidLite SDK Python check
AidLite Python API Deployment ​
Run the Python API Example
cd /home/aidlux/sam2-tiny/model_farm_sam2_qcs8550_qnn2.36_fp16_aidlite
# --imgs: Input image
# --point-coordinates: Prompt coordinates
# --invoke_nums: Loop iterations
python3 python/run_test.py --imgs python/truck.jpg --point-coordinates "500,375;1100,600" --invoke_nums 10
The terminal will display the model inference latency (in ms) and segmentation results:
plain
Encoder model invoke 10 times:
 --mean_invoke_time is 216.16535186767578
 --max_invoke_time is 221.62842750549316
 --min_invoke_time is 214.51592445373535
 --var_invoketime is 3.8429782512139354
[2026-02-10 15:26:06.024] [info] [license.cpp:520] the device is licensed, with license ID: aidf70cf68561ab0f1555c98a624584610b
PluginManager::load_plugin(): plugin(=aidlite_qnn236) has been loaded
w:1800, h:1200
Decoder model invoke 10 times:
 --mean_invoke_time is 6.911730766296387
 --max_invoke_time is 7.040739059448242
 --min_invoke_time is 6.859779357910156
 --var_invoketime is 0.0025213859089490143
Result images saved to 'python/mask_results.jpg'
The result image mask_results.jpg is saved in the path /home/aidlux/sam2-tiny/model_farm_sam2_qcs8550_qnn2.36_fp16_aidlite/python.
