Edge Deployment of Qwen3 Series ​
Qwen3 is the latest generation of large language models in the Qwen series, providing a complete suite of dense models and Mixture-of-Experts (MoE) models. Through large-scale training, Qwen3 has achieved breakthrough progress in reasoning, instruction following, agent capabilities, and multilingual support.
This chapter demonstrates how to perform Qwen3 series model deployment, loading, and conversation on edge devices. Two deployment methods are provided:
  • AidGen C++ API
  • AidGenSE OpenAI API
In this case, the large language model inference runs on the device side, and the relevant interfaces are called through code to receive user input and return conversation results in real time.
  • Device: Rhino Pi-X1
  • System: Ubuntu 22.04
  • Model: Qwen3-1.7B
Supported Platforms ​
PlatformRunning Method
Preparation ​
  1. Rhino Pi-X1 hardware
AidGen Case Deployment ​
Step 1: Install the AidGen SDK ​
# Install AidGen SDK
sudo aid-pkg -i aidgen-sdk
sudo aid-pkg -i aidgen-qnn236
sudo aid-pkg -i aidgen-qnn240
# Copy test code
cd /home/aidlux/aidllm
Step 2: Download Model Resources ​
Since Qwen3-1.7B is currently in the Model Farm preview section, it must be retrieved via the mms command.
# Log in
mms login
# Search for the model
mms list qwen3
# Download the model
mms get -m Qwen3-1.7B -p w4a16 -c qcs8550 -b qnn2.36 -d /home/aidlux/aidllm/qwen3-1.7b
cd /home/aidlux/aidllm/qwen3-1.7b
unzip qnn236_qcs8550_cl4096.zip
mv qnn236_qcs8550_cl4096/* /home/aidlux/aidllm/
Step 3: Create the Configuration File ​
vim qwen3-1.7b-aidgen-config.json
Create the following json configuration file:
json
    "backend_type": "genie",
    "prefix_path": "kv-cache.primary.qnn-htp",
    "model": {
        "path": [
            "qwen3-1.7b_qnn236_qcs8550_cl4096_1_of_3.serialized.bin.aidem",
            "qwen3-1.7b_qnn236_qcs8550_cl4096_2_of_3.serialized.bin.aidem",
            "qwen3-1.7b_qnn236_qcs8550_cl4096_3_of_3.serialized.bin.aidem"
Step 4: Confirm Resource Files ​
/home/aidlux/aidllm
├── chat-think.txt
├── chat-nothink.txt
├── qwen3-1.7b-aidgen-config.json
├── kv-cache.primary.qnn-htp
├── qwen3-1.7b_qnn236_qcs8550_cl4096_1_of_3.serialized.bin.aidem
├── qwen3-1.7b_qnn236_qcs8550_cl4096_2_of_3.serialized.bin.aidem
├── qwen3-1.7b_qnn236_qcs8550_cl4096_3_of_3.serialized.bin.aidem
├── examples
Step 5: Compile and Run ​
# Compile
mkdir build && cd build
cmake .. && make
./test_text_only qwen3-1.7b-aidgen-config.json "hi"
Log Information
AidGenSE Case Deployment ​
Step 1: Install AidGenSE ​
# Ensure aidgense is the latest version
sudo aid-pkg remove aidgense
sudo aid-pkg -i aidgense
Step 2: Model Query & Retrieval ​
# View models
aidllm remote-list api | grep Qwen3
#------------------------ You can see the Qwen3 models ------------------------
Current Soc : 8550
Name                                                    Url                                                           CreateTime
qwen3-0.6b-qnn2.36-w4a16-qcs8550                        aplux/qwen3-0.6b-qnn2.36-w4a16-qcs8550                        2026-05-15 10:59:35
qwen3-1.7b-qnn2.36-w4a16-qcs8550                        aplux/qwen3-1.7b-qnn2.36-w4a16-qcs8550                        2026-05-15 10:57:37
qwen3-4b-basic-quant-qnn2.36-w4a16-qcs8550              aplux/qwen3-4b-basic-quant-qnn2.36-w4a16-qcs8550              2026-05-15 10:59:47
qwen3-4b-instruct-2507-qnn2.36-w4a16-qcs8550            aplux/qwen3-4b-instruct-2507-qnn2.36-w4a16-qcs8550            2026-05-15 10:57:45
# Download qwen3-1.7B-8550
aidllm pull api aplux/qwen3-1.7b-qnn2.36-w4a16-qcs8550
Step 3: Start the HTTP Service ​
# Start the OpenAI API service for the corresponding model
aidllm start api -m qwen3-1.7b-qnn2.36-w4a16-qcs8550
# Check status
aidllm status api
# Stop service: aidllm stop api
# Restart service: aidllm restart api
The default port is 8888.
Step 4: Chat Test ​
Chat Test via Web UI ​
# Install UI frontend service
sudo aidllm install ui
# Start UI service
aidllm start ui
# Check UI service status: aidllm status ui
# Stop UI service: aidllm stop ui
After the UI service starts, visit http://ip:51104.
Chat Test via Python ​
import os
import requests
import json
def stream_chat_completion(messages, model="qwen3-1.7b-qnn2.36-w4a16-qcs8550"):
    headers = {
    payload = {
        "model": model,
        "messages": messages,
        "stream": True    # Enable streaming
    # Make request with stream=True
    response.raise_for_status()
    # Read line by line and parse SSE format
        if not line:
            continue
        # print(line)
        # Each SSE line starts with the "data: " prefix
            # End marker
            if data.strip() == "[DONE]":
                break
            try:
                chunk = json.loads(data)
            except json.JSONDecodeError:
                # Print and skip when parsing fails
                print("Unable to parse JSON:", data)
                continue
            # Extract the model output token
            if content:
if __name__ == "__main__":
    # Example conversation
    messages = [
        {"role": "system", "content": ""},
        {"role": "user", "content": "Give me a short introduction to large language model."}
    print("Assistant:", end=" ")
    print()  # New line
