Deploying LLM HTTP Server with AidGenSE ​
Deploying a Large Language Model (LLM) on edge devices refers to compressing, quantizing, and deploying large models that originally run in the cloud onto local devices, enabling offline, low-latency natural language understanding and generation. This chapter is based on the AidGenSE inference engine and demonstrates how to deploy an LLM HTTP service (compatible with the OpenAI API) on an edge device.
In this case, the large language model inference runs on the device side, and the relevant interfaces are called through HTTP API to receive user input and return conversation results in real time.
  • Device: Rhino Pi-X1
  • System: Ubuntu 22.04
  • Model: Qwen2.5-0.5B-Instruct
Supported Platforms ​
PlatformRunning Method
Preparation ​
  1. Rhino Pi-X1 hardware
Case Deployment ​
Step 1: Install AidGenSE ​
sudo aid-pkg -i aidgense
sudo aid-pkg -i aidgen-sdk
sudo aid-pkg -i aidgen-qnn236
sudo aid-pkg -i aidgen-qnn240
Step 2: Model Query & Retrieval ​
  • View supported models:
# View supported models
aidllm remote-list api
#------------------------ Example output is as follows ------------------------
Current Soc : 8550
Name                                 Url                                          CreateTime
qwen2.5-0.5B-Instruct-8550           aplux/qwen2.5-0.5B-Instruct-8550             2025-03-05 14:52:23
qwen2.5-3B-Instruct-8550             aplux/qwen2.5-3B-Instruct-8550               2025-03-05 14:52:37
  • Download Qwen2.5-0.5B-Instruct:
# Download the model
aidllm pull api aplux/qwen2.5-0.5B-Instruct-8550
# View downloaded models
aidllm list api
Step 3: Start the HTTP Service ​
# Start the OpenAI API service for the corresponding model
aidllm start api -m qwen2.5-0.5B-Instruct-8550
# Check status
aidllm status api
# Stop service: aidllm stop api
# Restart service: aidllm restart api
The default port is 8888.
Step 4: Chat Test ​
Chat Test via Web UI ​
# Install UI frontend service
sudo aidllm install ui
# Start UI service
aidllm start ui
# Check UI service status: aidllm status ui
# Stop UI service: aidllm stop ui
After the UI service starts, visit http://ip:51104.
Chat Test via Python ​
import os
import requests
import json
def stream_chat_completion(messages, model="qwen2.5-0.5B-Instruct-8550"):
    headers = {
    payload = {
        "model": model,
        "messages": messages,
        "stream": True    # Enable streaming
    # Make request with stream=True
    response.raise_for_status()
    # Read line by line and parse SSE format
        if not line:
            continue
        # print(line)
        # Each SSE line starts with the "data: " prefix
            # End marker
            if data.strip() == "[DONE]":
                break
            try:
                chunk = json.loads(data)
            except json.JSONDecodeError:
                # Print and skip when parsing fails
                print("Unable to parse JSON:", data)
                continue
            # Extract the model output token
            if content:
if __name__ == "__main__":
    # Example conversation
    messages = [
        {"role": "user", "content": "Hello."}
    print("Assistant:", end=" ")
    print()  # New line
