Deploying VLM with AidGen ​
Deploying a vision language model (VLM) on edge devices refers to compressing, quantizing, and deploying large models that originally run in the cloud onto local devices, enabling offline, low-latency natural language understanding and generation. This chapter is based on the AidGen inference engine and demonstrates how to perform deployment, loading, and conversation of multimodal large models on edge devices.
In this case, the multimodal large model inference runs on the device side, and the relevant interfaces are called through C++ code to receive user input and return conversation results in real time.
  • Device: Rhino Pi-X1
  • System: Ubuntu 22.04
  • Model: Qwen2.5-VL-3B (392x392)
Supported Platforms ​
PlatformRunning Method
Preparation ​
  1. Rhino Pi-X1 hardware
Case Deployment ​
Step 1: Install the AidGen SDK ​
# Install AidGen SDK
sudo aid-pkg -i aidgen-sdk
sudo aid-pkg -i aidgen-qnn236
sudo aid-pkg -i aidgen-qnn240
# Copy test code
mkdir /home/aidlux/aidmlm
cd /home/aidlux/aidmlm
Step 2: Model Acquisition ​
Since Qwen2.5-VL-3B (392x392) is currently in the Model Farm preview section, it must be retrieved via the mms command.
# Log in
mms login
# Search for the model
mms list Qwen2.5-VL-3B
# Download the model
Step 3: Create the Configuration File ​
vim config3b_392.json
Create the following json configuration file:
json
    "backend_type": "genie",
    "model": {},
    "vlm_model":{
        "llm_path_list":[
/home/aidlux/aidmlm
├── full_attention_mask.raw
├── position_ids_cos.raw
├── position_ids_sin.raw
├── veg.serialized.bin.aidem
├── window_attention_mask.raw
├── examples
Step 4: Compile and Run ​
mkdir build && cd build
cmake .. && make
# Manually upload an image to the /home/aidlux/aidmlm/ directory
./test_multimodal config3b_392.json test-1.jpg "Please describe this image"
  • The running result is shown below:
Log Information
