AidLite Development Documentation ​
AidLite SDK is an AI execution framework developed by APLUX, designed to fully utilize the computing units (CPU, GPU, NPU) of edge devices to achieve accelerated AI model inference.
AidLite standardizes AI inference middleware across platforms. It abstracts calls to different AI frameworks into a unified API, allowing for decoupled and flexible model inference development.
  • Compatible with mainstream AI frameworks.
  • Supports proprietary frameworks of AI chip vendors (Qualcomm, RockChip, etc.) and enables calls to vendor-specific AI compute units (NPU).
The features are illustrated below:
AidLite's highly unified API abstraction supports different AI frameworks, allowing developers to build once and deploy across different chips and frameworks. This greatly reduces learning costs and platform migration difficulties, enabling flexible technical choices and faster product deployment.
Supported Matrix ​
Operating System Support
LinuxAndroid
C++✅/
Python✅/
Java/✅
Android SDK is a premium enterprise service. Contact Sales
AI Framework Support
Qualcomm SNPEQualcomm QNNRKNNTFLiteONNX
AidLite for Linux✅✅✅✅✅
AidLite for Android✅✅✅✅✅
✅: Supported
🚧: Planning
Quick Start ​
AidLite integrates multiple deep learning inference frameworks at the backend, so the inference process and required APIs remain highly consistent regardless of the model framework.
Installation ​
sudo aid-pkg install aidlite
In Linux, to install AidLite SDK with a specific QNN version: sudo aid-pkg install aidlite-{QNN Version}
Example: To install AidLite SDK with QNN 2.16 — sudo aid-pkg install aidlite-qnn216
  • Validating AidLite Installation
# aidlite sdk c++ check
# aidlite sdk python check
Development Flowchart ​
Development Workflow Explanation ​
The following code demonstrates the core development flow. For full API details, refer to the AidLite API Documentation.
The following points should be noted when developing with AidLite SDK in C++:
  • During compilation, you need to include the header file located at /usr/local/include/aidlux/aidlite/aidlite.hpp.
  • During linking, you need to specify the library file located at /usr/local/lib/libaidlite.so.
Python
# Print SDK version and configure logging
# aidlite.log_to_stderr()
# Create a Model instance and set model parameters
if model is None:
    return False
# Create a Config instance and set configuration
if config is None:
 print("build_interpreter_from_model_and_config failed !")
 return False
# for special qnn version
# config.framework_type = aidlite.FrameworkType.TYPE_QNN231
config.is_quantify_model = 1
# Build the inference interpreter
fast_interpreter = aidlite.InterpreterBuilder.build_interpreter_from_model_and_config(model, config)
if fast_interpreter is None:
        return None
# Initialize the interpreter
if result != 0:
    return False
# Load the model
if result != 0:
    return False
# Complete inference process typically involves: Preprocessing + Inference + Postprocessing
# Preprocessing varies by model
# Set the input tensor data for inference
if result != 0:
    return False
# Run inference
if result != 0:
    print("interpreter invoke() failed")
    return False
# Retrieve output tensor data
if out_data is None:
    return False
# Postprocessing varies by model
# Release interpreter resources
result = fast_interpreter.destroy()
if result != 0:
    print("interpreter destroy() failed !")
    return False
C++
// Get SDK version info and configure logging
// Create a Model instance and set model properties
if(model == nullptr){
// Create a Config instance and set configuration
if(config == nullptr){
config->framework_type = FrameworkType::TYPE_QNN;
config->accelerate_type = AccelerateType::TYPE_DSP;
// Build the inference interpreter
    printf("build_interpreter_from_model_and_config failed !\n");
// Initialize the interpreter
if(result != EXIT_SUCCESS){
// Load the model
result = fast_interpreter->load_model();
// Inference workflow typically includes: Preprocessing + Inference + Postprocessing
    // Preprocessing varies by model
    // Set input tensor data
    // Run inference
    // Get output tensor data
    float* out_data = nullptr;
    // Postprocessing varies by model
// Release interpreter resources
result = fast_interpreter->destroy();
    printf("interpreter->destroy() failed !\n");
Example ​
Developers can access Model Farm to download more model examples (including pre-processing and post-processing).
Using AidLite (QNN2.31) to Run YOLOv5 Inference on Qualcomm NPU ​
AidLite provides a YOLOv5 example in the Linux environment, located at /usr/local/share/aidlite/examples/. The step to run example showed below:
Python
python qnn_yolov5_multi.py
C++
sudo apt-get install cmake -y
mkdir -p build && cd build
cmake ..
make
/xxx.exe
