BEVFormer-tiny (R50) Deployment ​
BEVFormer-tiny (R50) is an autonomous-driving multi-camera 3D object detection model focused on efficient edge deployment. It was proposed by the SenseTime and Tsinghua University teams. Built on the classic ResNet-50 backbone, it uses a unique Spatio-Temporal Attention mechanism to losslessly convert 2D image features from multiple surround-view cameras into a unified surround-view Bird's-Eye View (BEV) feature. As the lightweight Tiny variant, it streamlines Transformer layers and optimizes grid resolution to dramatically reduce memory footprint and inference latency, while still fully preserving velocity estimation and temporal trajectory tracking for dynamic objects. With its excellent energy-efficiency ratio, BEVFormer-tiny has become an industry benchmark for high-precision 3D spatial perception and vehicle-road coordination on low-compute automotive chips and Roadside edge computing units (RSCU).
This chapter demonstrates how to perform BEVFormer-tiny (R50) deployment, loading, and recognition on edge devices. The following deployment method is provided:
  • AidLite Python API
In this case, model inference runs on the device-side NPU computing unit, and the relevant interfaces are called through code to receive user input and return results.
Supported Platforms ​
PlatformRunning Method
Preparation ​
  1. Rhino Pi-X1 hardware
Download the BEVFormer-tiny (R50) Model Resources ​
mms list BEVFormer-tiny
#------------------------ You can see the BEVFormer-tiny (R50) model ------------------------
Model                 Precision  Chipset  SOC               Backend
BEVFormer-tiny (R50)  FP16       qcs8550  Qualcomm QCS8550  QNN2.40
# Download BEVFormer-tiny (R50)
mms get -m 'BEVFormer-tiny (R50)' -p fp16 -c qcs8550 -b qnn2.40 -d /home/aidlux/models-test
cd /home/aidlux/models-test
# Unzip
unzip BevFormer-Tiny-Resnet50_qcs8550_fp16.zip
AidLite SDK Installation ​
Developers can also refer to the README.md in the model folder to install the SDK.
  • Ensure the QNN backend version is ≥ 2.40
  • Ensure aidlite-sdk and aidlite-qnnxxx versions are 2.4.x or higher
dpkg -l | grep aidlite
#------------------------ The output is similar to the following ------------------------
Update QNN & AidLite versions:
# Install AidLite SDK
# aidlite sdk c++ check
# aidlite sdk python check
AidLite Python API Deployment ​
Run the Python API Example
cd /home/aidlux/models-test/
python3 code/python/run_test.py \
  --backbone_model ./models/QCS8550/FP16/backbone_context.bin.aidem \
  --scene_start_encoder_model ./models/QCS8550/FP16/scene_start_encoder_context.bin.aidem \
  --encoder_model ./models/QCS8550/FP16/temporal_encoder_context.bin.aidem \
  --decoder_model ./models/QCS8550/FP16/decoder_context.bin.aidem \
  --asset_manifest ./code/python/datasets/sample4/asset_manifest.json \
  --nms_contract ./code/python/configs/nms_runtime_contract.json \
  --model_type QNN240 \
  --invoke_nums 4 \
  --output_dir ./outputs/final_sample4
You can see the model inference time (in ms) and detection results in the command line:
plain
BEVFormer W8A8 QCS8550 Performance
model platform   : QCS8550
frames           : 4
QNN invoke (ms)  : mean=401.968  min=400.651  max=403.298
  backbone       : 18.089
  encoder        : 344.693 (scene_start)  345.820 (temporal)
  decoder        : 38.341
Output files
  summary JSON   : /home/aidlux/models-test/outputs/final_sample4/bevformer_demo_summary.json
  camera-grid PNG: 4 frame(s)
  camera-grid GIF: /home/aidlux/models-test/outputs/final_sample4/sample4_camera_grid.gif
After the example program runs, the final dynamic detection image sample4_camera_grid.gif will be generated under /home/aidlux/models-test/outputs/final_sample4/.
