Deploy VLM HTTP Server with AidGenSE ​
Edge deployment of Vision Language Models (VLM) refers to the process of compressing, quantizing, and deploying large models originally run in the cloud onto local devices to enable offline, low-latency natural language understanding and generation. This chapter uses the AidGenSE inference engine as a base to demonstrate how to deploy a multi-modal large model HTTP service (compatible with the OpenAI API) on edge devices.
In this case, the multi-modal large model inference runs on the device side. Relevant interfaces are called via HTTP API to receive user input and return dialogue results in real time.
  • Device: Rhino Pi-X1
  • System: Ubuntu 22.04
  • Model: Qwen2.5-VL-3B (392x392)
Supported Platforms ​
PlatformRunning Method
Preparation ​
  1. Rhino Pi-X1 hardware
Case Deployment ​
Step 1: Install AidGenSE ​
sudo aid-pkg -i aidgense
sudo aid-pkg -i aidgen-sdk
sudo aid-pkg -i aidgen-qnn236
sudo aid-pkg -i aidgen-qnn240
Step 2: Model Query & Acquisition ​
  • View supported models
# View supported models
aidllm remote-list api
#------------------------Example output is as follows------------------------
Current Soc : 8550
Name                                                    Url                                                           CreateTime
qwen2.5-vl-3b-instruct-392x392-qnn2.36-w4a16-qcs8550    aplux/qwen2.5-vl-3b-instruct-392x392-qnn2.36-w4a16-qcs8550    2026-05-15 10:57:51
qwen2.5-vl-3b-instruct-672x672-qnn2.36-w4a16-qcs8550    aplux/qwen2.5-vl-3b-instruct-672x672-qnn2.36-w4a16-qcs8550    2026-05-15 10:57:49
  • Download qwen2.5-vl-3b-instruct-392x392-qnn2.36-w4a16-qcs8550
# Download the model
aidllm pull api aplux/qwen2.5-vl-3b-instruct-392x392-qnn2.36-w4a16-qcs8550
# View downloaded models
aidllm list api
Step 3: Start the HTTP Service ​
# Start the openai api service for the corresponding model
aidllm start api -m qwen2.5-vl-3b-instruct-392x392-qnn2.36-w4a16-qcs8550
# Check status
aidllm status api
# Stop service: aidllm stop api
# Restart service: aidllm restart api
The default port number is 8888.
Step 4: Dialogue Test ​
Dialogue Test Using Web UI ​
# Install the UI front-end service
sudo aidllm install ui
# Start the UI service
aidllm start ui
# Check UI service status: aidllm status ui
# Stop UI service: aidllm stop ui
After starting the UI service, access http://ip:51104.
Dialogue Test Using Python ​
import os
import sys
import requests
import json
import base64
def stream_chat_completion(messages, model="qwen2.5-vl-3b-instruct-392x392-qnn2.36-w4a16-qcs8550"):
    headers = {
    payload = {
        "model": model,
        "messages": messages,
        "stream": True    # Enable streaming
    # Send request with stream=True
    try:
        response.raise_for_status()
    except requests.HTTPError as e:
        print(f"\nHTTP error: {e}", file=sys.stderr)
        if response.text:
            print(response.text, file=sys.stderr)
        raise
    # Read and parse SSE format line by line
        if not line:
            continue
        # print(line)
        # Each line of SSE starts with the "data: " prefix
            # End flag
            if data.strip() == "[DONE]":
                break
            try:
                chunk = json.loads(data)
            except json.JSONDecodeError:
                # Print and skip when parsing fails
                print("Failed to parse JSON:", data)
                continue
            # Extract the token output by the model
            if content:
def image_to_data_url(image_path):
    """Read an image and convert it to a data URL, compatible with the OpenAI-style image_url field."""
    ext = os.path.splitext(image_path)[1].lower()
    mime_map = {
        ".jpg": "image/jpeg",
        ".jpeg": "image/jpeg",
        ".png": "image/png",
        ".webp": "image/webp",
    mime_type = mime_map.get(ext, "image/jpeg")
    b64_str = image_to_base64(image_path)
    return f"data:{mime_type};base64,{b64_str}"
if __name__ == "__main__":
    image_url = image_to_data_url("/path/to/your/image.jpg")
    # Example dialogue
    messages = [
            "role": "system",
            "content": "You are a helpful assistant."
            "role": "user",
            "content":[
                            "type": "text",
                            "text": "Describe the content of this image."
                            "type": "image_url",
                            "image_url":
                                "url": image_url
    print("Assistant:", end=" ")
    print()  # New line
