AidStream Python API ​
AidStream Python API Reference ​
Overview ​
AidStream provides Python bindings (via pybind11) that allow developers to call AidStream SDK core functionality from Python. The Python binding module is named aidstreamgst.
The Python bindings currently expose only a subset of the C++ API. Some advanced features (such as AidStreamEngine, Splice API, rolling recording, etc.) are not yet available in Python.
Installation and Import ​
import aidstreamgst
Enumerations ​
LogLevel ​
MemberDescription
LogLevel.SINFOInformational log level
LogLevel.SWARNINGWarning log level
LogLevel.SERRORError log level
LogLevel.SDEBUGDebug log level
LogLevel.SOFFLogging disabled
StreamType ​
The Python bindings expose only 3 of the 5 StreamType values. RTMPSINK and MP4 types are currently unsupported.
MemberDescription
StreamType.EMPTYNo output (fakesink)
StreamType.WAYLANDSINKWayland display output
StreamType.RTSPSINKRTSP streaming output
Image Class ​
The Image class encapsulates frame data and metadata received from the GStreamer pipeline callback.
PropertyTypeDescription
widthintImage width
heightintImage height
sizeintBuffer size occupied by the image data (bytes)
fpsfloatFrame rate (C++ type is double; in Python it appears as float)
pipe_statusintPipeline status
MethodDescription
to_bytes()Copies the current frame data into a Python bytes object (thread-safe)
as_memoryview()Returns a zero-copy memoryview of the current frame data (does not hold the underlying memory; only safe within the callback)
def my_callback(img):
    # Access frame dimensions and frame rate
    print(f"width: {img.width}, height: {img.height}, fps: {img.fps}")
    # Get image data as bytes
    raw_bytes = img.to_bytes()
    # Or get a zero-copy memory view (only valid inside the callback)
    mem = img.as_memoryview()
    return 0
mat_image Class ​
mat_image wraps an OpenCV cv::Mat object for Python. It supports the buffer protocol, so it can be directly converted to a numpy array.
MethodDescription
is_empty()Returns True if the image is empty
import numpy as np
    mat = aidstreamgst.get_data(img.height, img.width, img.to_bytes())
    if mat.is_empty():
        print("Empty image")
        return -1
    arr = np.array(mat, copy=False)
    # Process arr...
    return 0
API Functions ​
set_log_level ​
Sets the log level.
ParameterTypeDescription
log_levelLogLevelLog level enum value
aidstreamgst.set_log_level(aidstreamgst.LogLevel.SINFO)
clogger ​
Creates log files and sets the log path and filename prefix.
destinationPathstrLog file path and prefix, e.g., "./aidclog_aidstream_"
aidstreamgst.clogger("./aidclog_aidstream_")
start_stream ​
Starts a stream by stream_id. This function is blocking. The callback is GIL-safe.
stream_idstrStream ID defined in the aidstream-gst.conf configuration file
cbCallable[[Image], int]Callback function that receives an Image object and returns an int (0 for success)
    print(f"Received frame: {img.width}x{img.height} at {img.fps}fps")
    return 0
# Start the stream (blocking call)
aidstreamgst.start_stream("stream1", my_callback)
shutdown ​
Stops the pipeline and releases resources. Equivalent to gstreamer_pipeline_shutdown() in C++.
ParameterTypeDefaultDescription
stream_idstr"all_stream"The stream ID to stop. Pass a specific stream ID to stop a single stream, or "all_stream" to stop all streams.
# Stop all streams
aidstreamgst.shutdown()
# Stop a specific stream
aidstreamgst.shutdown("stream1")
get_data ​
Converts image data into an OpenCV Mat object.
widthintImage width
databytesRaw image data (obtained via img.to_bytes())
get_stream_status ​
Returns the current running status of the stream.
Return ValueDescription
1Stream is running
0Stream is idle
-1Uninitialized
status = aidstreamgst.get_stream_status()
print(f"Stream status: {status}")
Complete Example ​
import aidstreamgst
import signal
running = True
    """Callback invoked for each video frame."""
    print(f"Frame: {img.width}x{img.height}, fps: {img.fps:.1f}")
    # Get image bytes
    img_bytes = img.to_bytes()
    return 0
def main():
    # Set up logging
    # Start stream using stream ID from the configuration file
    aidstreamgst.start_stream("1", my_callback)
if __name__ == "__main__":
    main()
